SCH Filter - Select Components
  • vietzung
    commented on 's reply
    viniciusserrano Or you can right click on component and select "Find similar objects..." and you can select components with the same conditions
    Depends what these resistors have common. But if you need to select specific components, you can use something like: "IsPart And ((PartDesignator = 'C3') or (PartDesignator = 'C2'))"
  • viniciusserrano
    It is possible select by designator?
    e.g. R201,R211,R307,R308,R321,R322,R401,R405,R600,R601, R602,R603 ,R604,R606,R608,R609,R610,R611,R612,R615,R619,R631 ,R632,R70 3,R704,R705,R706,R707,R708,R709,R712,R714,R715,R71 7,R718,R7 19,R720,R724,R725,R726,R727,R728,R809,R810,R906,R9 09
    You can play with different filters, e.g. try to use "IsPart And (Description Like 'RES*')". I am not sure what your listed resistors have common, but here is an example to select all resistors in my schematic page:
Name:	search for part.jpg
  • viniciusserrano
    How can I use SCH Filter for this?
    I would use SCH Filter, that should work.
  • viniciusserrano
    started a topic SCH Filter - Select Components
    Hello
    ​How can I select componentes in multiple sheet? I need select and chance the supplier part number for all specific componente:
