Length trace with through vias
  • Paul van Avesaath
    Originally posted by baoNG View Post
    Hi Sir!
    I have one problem.
    In my project, i have trace with through vias, length of this trace = signal length + the depth of the vias (thickness of pcb).
    when i layout the signal from Top_layer to Layer 3 ( pcb 6 layer , thickness 1.2mm, deelectric 1 to layer 3 is 0.25) the length of this trace = signal length + 1.2mm. like image
    it is wrong?
    Thank you so much
    If you need to route with via length in mind, save yourself the hassle and route all similar signals on the same layer. so if you can go to Toplayer-> via->mid layer->via-> bottomlayer. if you use all signals that way you dont need to calculate signal via length.
    also like robert mentioned, use Xsignals that way all will be taken into account.
    It looks to me, that there is a small connection missing on the bottom layer. Also, if you need to include length in VIAs, maybe consider using xSignals - that should give you more accurate results.
  • baoNG
    commented on 's reply
    Hi Muhmmad Ahsan!
    Thank you for your comment, i have just fixed it, it is my wrong when config stackup.
    how do delete my post?
    thank you so much.
  • Muhmmad Ahsan
    Hello
    BaoNg,
    You may route another small trace on your actual one that why is showing this difference result
    My opinion is that delete the existence trace and make it new one
  • baoNG
    started a topic Length trace with through vias
    Hi Sir!
    I have one problem.
    it is wrong?
    Thank you so much
