HDMI Routing
    robertferanec
    Administrator
    All signals in your interface are strobed by common signal (CLK), so you can not really separate the data into groups (means you need to work with D0 - D23 together). You only can split interface into groups if each group has it's own strobe signal(s).
    We do lenght match this kind of interface, but I do not know the exact requirements for this chip. Maybe try to find some design guides (or just make D0 - D23 similar length, and CLK the longest). If it helps, have a look at our open source board, we have similar chip there (but the other direction) ... you can check the layout and measure the tracks, here is the link: http://www.imx6rex.com/imx6-tiny-rex/baseboard-lite/
  • mohsin_qau
    Member
  • mohsin_qau
    You can switch to other routing layers. Means u route D0-D15 in one routing layer and D16-D23 to other routing layer and match therm with Clock signal.
  • meet
    Junior Member
  • meet
    started a topic HDMI Routing
    HDMI Routing
    Hello Robert,
    I am using ADV7513_for HDMI interface. i get stucked for the routing of color signal D[23.0]. this are single ended traces. i need guidance about their trace length matching..
    1. should i length match the trace length for particular color group? for example D0-D7 should be length match and D8-D15 and D16-D23
    2. Or all Signals from D0-D23 should be length matched. presently it is impossible for me to match them.
    3. what is the relation for HDMI clock to these video capture signal D0-D23
