Net Class in Altium 18
  • Net Class in Altium 18
    Alt / Place / Directives submenu doesn't have Net Class option in Altium 18.
    I tried placing the Blanket and Parameter Set but it did not work the Net class is not shown in the .PcbDoc
    What is the right way to create a Net Class in Altium 18?
    place the parameter set, then in the properties panel? then update schematic to PCB.. it should come up in there
      Also, easy way is to open an existing project in AD18 (e.g. you can use one of our open source boards from http://www.imx6rex.com/ ) and as Paul van Avesaath suggested, you will find it then in the Properties panel. Based on existing project you will know exactly how to set it up in your own project.
Name:	net class in AD18 v2.jpg
        I did not put Parameter Set. I put DIFF100 in Schematic on nets which need to be routed by 100 ohm. I added Differential Pair Class also. I think it is L4 in Advanced PCB LC
        Best regards,
        Milos
