Hello , if i have a pcb with juste 2 layers , what's the best diametre of vias and why ??
Vias for 2 layer pcb card
Originally posted by karimoviç View PostHello , if i have a pcb with juste 2 layers , what's the best diametre of vias and why ??
E.G: https://welldoneblog.fedevel.com/202...ions-and-more/
https://welldoneblog.fedevel.com/201...in-pcb-layout/
- 1 like
I would add also this: How to design cheaper PCB? What the parameters on PCB manufacturer website mean? https://youtu.be/NyVjg6-wfvY
Basically, you take minimum recommended cheap hole (usually 0.3mm) and minimum recommended cheap track width (often 0.15mm), that will make minimum recommended cheap VIA 0.3mm hole and 0.6mm pad size (calculated like: 0.15 ring on one side + 0.3 hole + 0.15 ring on other side of VIA).
